So I plunged for an endgame sub upgrade. A bit of background. I’m running a Focal Utopia Scala Evo front end driven by big Chord monos. Sub duties have been thanks to 2 Rel Carbon Specials at the front and a Rel 212 SX at the rear. The results were impressive. Well integrated tight bass with real slam and speed. My room is only 4.8m by 4.8m into a bay, so narrows to 3m, it’s not massive.
However I am struggling with any real response below about 27 hz where my room has quite a null. Recently listening to a friends room with his 18in DIY sub brought home the missing depths…
So arriving on Wednesday, courtesy of Nick @ The Sound Counsel are 2 Ascendo SMSG15’s (a 15in driver compared to the 12in in the Rels) and an SMSG24 infrasonic sub (a 24in driver with 6kw amp). It’s total overkill for the room size but should give huge dynamics and punch down to low teens hz with ease.
I’ll report back, but this represents my holy grail for low end response. I’m looking forward to re calibrating the room on the Trinnov to play around with crossovers, but going to start with a 60 hz roll off on the front array, with the 2 15’s handling everything including LFE down to 40hz. The 24 will then pick up everything below 40hz. I’ll set the Trinnov to treat the 3 subs as a single 3 way speaker to achieve EQ and phase so they work together.
