end the headache please!
Discussion in 'PC Gaming & Rigs' started by markymark34, Apr 29, 2004.
  1. markymark34
    markymark34
    Dec 15, 2002
    3,241
    Northern Ireland
    +328
    I have a athlon xp1800
    512mb ddr ram
    a ti200 i think! graphics card
    80gb hard drive
    Problem is my computer over night has gone from being fast (enough for me) to unbelievable slow. More than a few windows open and its in trouble. I cant think what to do. Applications wont close properly either. I have since then done a completely fresh instal of xp pro on a new hard drive and im still having the same problems. Any ideas guys?
    driving me nuts!
    Mark
  2. nathsea
    nathsea
    Apr 26, 2003
    917
    +24
    is your memory just one stick of 512 or 2 x 256? if it is 2, have one of these died? does it count up to 512 in the memory test in the bios?
    Nathan
  3. markymark34
    markymark34
    Dec 15, 2002
    3,241
    Northern Ireland
    +328
    its 1 stick of 512. and it seems to be fine in the memory test
    It really has me confused
  4. ELV
    ELV
    Jun 5, 2001
    672
    Up in the proper north
    +9
    Are there any processes running with high cpu usage, sounds like it could be a trojan of somekind, my mate had exactly the same problem, have a look in the task manager, if u do have one and can't remove it do a format and BEFORE doing anything else on the web install a good firewall then virus checker and THEN update it on the web, then it should be fine and don't forget to update windows aswell.
    I fit's not a trojan then all the above is usless to you!!!
  5. Venom1969
    Venom1969
    I'd recommend what ELV says. Also defragging your hard drive works wonders, almost as good as a fresh install without the need to reinstall all your programs again. Don't bother with the integrated defrag it's almost useless. Try diskeeper or my favourite O&O defrag, defrags even the messiest drives with little or no extra space required! :)
  6. HMHB
    HMHB
    Nov 11, 2001
    25,593
    Nottinghamshire
    +3,943
    I can't see how a defrag or searching for a trojan could be the answer as he's done a fresh install on a fresh hard disk.
    Is the chip running at the correct speed ? Have you tried a download of some benchmarking software and run that ?
  7. GrahamC
    GrahamC
    Jul 22, 2001
    2,258
    Morecambe, U.K.
    +67
    Check the memory is running at the right speed, if it's sliped from 133 to 100 the speed loss feels a lot more than a 33 slow down.
  8. andy572
    andy572
    Dec 4, 2002
    361
    Oop North
    Thinking along similar lines, it's worth checking that the BIOS settings are being held and that the correct FSB/multiplier settings are currently saved.
    If not, the solution could be as simple as replacing the on-board battery that is usually used (typically a 'CR2035', I think).
    Just in case it's needed, your processor-related settings should be:
    FSB 133 (266), multiplier 11.5x, giving an actual processor speed of 1533 MHz and the '1800+' rating.
    Hmm, not just hankering for that Athlon 64 upgrade are you...? :laugh:
    Good luck and I hope that helps :)
  9. ELV
    ELV
    Jun 5, 2001
    672
    +9
    As i said exactly the same thing happened to my mate, multiple windows would struggle to open, programes would run very slow and this all happened overnight!
    The reason i said putting the fire wall on first is because he also formated his hard drive and it was re-infected within seconds of going back online.I'm not an expert but Marks symptoms are identical my mates,he also bought a new hard disk and it was re-infected also, the answer is protect yourself before going online with a firewall and virus checker(Norton has been spot on in both my case and my mates, he did'nt have one before)and update it first then windows.
    By all means Mark check the above first but don't disscount what iv'e said my mate was at his wits end also, and if you're not an expert i know how annoying it can all be!
    Hope you sort it out ...:confused: :confused:
  10. markymark34
    markymark34
    Dec 15, 2002
    3,241
    Northern Ireland
    +328
    thanks guys i wil try some of those settings when i get home.
    Its definately not a trojan or a virus. Brand new hard drive without an internet connection for a few days and it was still slow.
    Is there much benifit in the Athlon 64? The komplett web site says its only a 10% performance gain on the barton chipset and there is over £100 difference in price on the packs?
    mark
  11. markymark34
    markymark34
    Dec 15, 2002
    3,241
    Northern Ireland
    +328
    right. changed the settings to 133 it was at 100 it now says i have a 1600+ at start up. Nearly at the 1800+ that i actually have!
    andy you mentioned multiplier 11.5x what does that mean?
    computer does seen faster now!!!
  12. GrahamC
    GrahamC
    Jul 22, 2001
    2,258
    Morecambe, U.K.
    +67
    Your chips actual speed is made up of the memory bus speed x the CPU clock multiplyer so if the mem is 133 then the multiplyer should be 13.5. Look in the bios for chip or CPU clock/multiplyer and set that to 13.5 and that will get it back to 1800. If you want to overclock try another setting, say 15 and this will speed your system up. Just remember that overclocking is a system by system trial and error thing. :thumbsup:
  13. markymark34
    markymark34
    Dec 15, 2002
    3,241
    Northern Ireland
    +328
    computer seems to be running better.
    but cant find the multiplier.
    In the setup i have an option of selection memory speed of 100 or 133. Thats the only option i can change in there. Went through all the other options as well. No mention of multiplier.
    I suppose this means i dont have to spend money on a new computer till some new games come out!
    mark
