encoder advice needed
Discussion in 'Camcorders, Action Cams & Video Editing Forum' started by dee416, Feb 15, 2003.
  1. dee416
    dee416
    want to turn my finished movie on to dvd do i need an encoder and which one how much and will it give reasonable quality dvd.at present i have a pioneer dvd burner and variouse dvd burning software but was told this is not suficient as i need an encoder can u help.
  2. Brian110507
    Brian110507
    What did you use to make the movie ???
    Most good video editing packages such as Pinnacle or U-lead Video studio or 'Movies on CD & DVD' from Magix all incorporate the ability to burn to CD or DVD at the final stage. These incorporate all you need to edit, add music and narration then make a CD or DVD with menus and work with your own CD or DVD burner, you do not need a seperate 'encoder' (whatever that may be)
