Enclosed gazebo/pergola - materials?
Discussion in 'General Chat' started by pbb76, Jul 19, 2018.
  1. pbb76
    pbb76
    May 29, 2007
    7,338
    Colchester, Essex
    +1,509
    We are in the middle of revamping our garden and considering one of those "Lay-Z" hot tubs.
    Bit worried about the noise of them, so thinking about enclosing it.
    We have a pergola frame and thinking of putting that up but enclosing it with wood on 3 sides (so front is open to garden) which may help drown out some of the noise from escaping?
    What sort of wood would (EDWARD WOODWARD!) be best to use to make something like that? (remember, have the wood framework, its just the sides).
    Over to you DIY experts! :)
  2. mooperman
    mooperman
    Apr 11, 2007
    12,878
    Notts
    +2,992
  3. pbb76
    pbb76
    May 29, 2007
    7,338
    Colchester, Essex
    +1,509
  4. Wahreo
    Wahreo
    Oct 11, 2012
    15,478
    +12,805
    Is the gazebo made from wood already?
    Just some treated 3” x 2” timber at the top and bottom horizontally and some vertical studs, then nail on some feather edge horizontally.
  5. pbb76
    pbb76
    May 29, 2007
    7,338
    Colchester, Essex
    +1,509
    Yea, Gazebo is thick wood beams.
    You lost me at "vertical studs" and "feather edge" :D Just so you know what you are dealing with...
    EDIT: Right, feather edge I get now- like fence panel wood, for the layman?
    Thanks, I think I could fashion something from that. Least I know where to look now!
  6. IronGiant
    IronGiant
    Jun 7, 2003
    67,529
    +48,310
    Yes, exactly that :thumbsup: Shed walls are frequently made from it. I'd suggest you go to a Garden Centre selling sheds and have a nose around the inside of a few to see how they are constructed.
  7. pbb76
    pbb76
    May 29, 2007
    7,338
    Colchester, Essex
    +1,509
    Good idea! Thank you :)
  8. Wahreo
    Wahreo
    Oct 11, 2012
    15,478
    +12,805
    Stage 1 and 2 in red. Done on my phone with my finger as you can see :D
  9. pbb76
    pbb76
    May 29, 2007
    7,338
    Colchester, Essex
    +1,509
    Perfect! thanks :)
  10. Wahreo
    Wahreo
    Oct 11, 2012
    15,478
    +12,805
    This is what I had in mind. At least then the featheredge or whatever cladding you use can fit nicely between the posts.
  11. pbb76
    pbb76
    May 29, 2007
    7,338
    Colchester, Essex
    +1,509
    Thank you, this is what I had in mind after the help above too, so thats good to know!
