Enabling component in on a 50MXE1
Discussion in 'Plasma TVs Forum' started by Kaz, Dec 16, 2004.
  1. Kaz
    Kaz
    friend of mine's been upgrading leads un stuff on his Pio 50MXE1 since I caught him feeding s-video into it for TV and DVD :oops: I think that's actually a crime isn't it?
    So he got some component leads and RCA to BNC adaptors 'cause he's got the the BNC inputs :suicide:
    But he can't select input 2 which is his component input of his card?
    He can't even get to the integrator menu as I can on me 43MXE-1.
    Any ideas?
  2. m_j_s
    m_j_s
    Nov 9, 2004
    11
    Melbourne
    You have said that the component input is no 2 on the card. This is not the same as the Pio card in which the 5xBNC is technically input 5 in total (or 3 on the card)
    Does he have a Pio card or some other maufacturer's card instead eg Aurora?
    Might this be affecting things?
    If he does have the Pio card, as I do, then he should select input 5 and configure to component in the normal menu
  3. Kaz
    Kaz
    yeah good question, my component in is on input 5. I'll ask about what type of card it is...
