enable wi-fi on ipaq rx 3715
Discussion in 'Mobile Phones Forum' started by eternaldark, Feb 24, 2005.
  1. eternaldark
    eternaldark
    Oct 23, 2004
    1,410
    Inverness
    +62
    Going mad!! cannot get my pc which has a wireless card to see my ipaq and vice versa, anyone show me an idiots guide to setting this up? using windows xp with an internal wi-fi card :lease:
  2. robocop
    robocop
    Oct 16, 2000
    646
    Old Detroit a.k.a. Chippenham. Wilts
    +23
  3. shoehorn
    shoehorn
    Jul 2, 2003
    1,601
    The Garden of England
    +32
    What have you "named" your PPC?
    See Start, Settings, System tab, About, Device ID tab.
    If you have changed your Devive name, ensure in only uses characters _, A-Z, a-z or 0-9
    I had this problem and solved it by the above.
    If not then I'd try the forum mentioned by robocop
    HTH
  4. eternaldark
    eternaldark
    Oct 23, 2004
    1,410
    Inverness
    +62
    Thanks will check it out :)
