Empty external firewire HD case
Discussion in 'Desktop & Laptop Computers Forum' started by tomson, Oct 13, 2003.
  1. tomson
    tomson
    Jul 19, 2000
    1,918
    Berk'amsted
    +187
    Can anyone recommend a good supplier of the above. It is needed to house at least one Seagate Barraccuda drive - might consider a dual bay one.
    Ideally I'm after one with 2 firewires sockets and an aluminium (or other non-plastic) case.
    Thanks.
  2. nathan_silly
    nathan_silly
  3. geordie_blerk
    geordie_blerk
    Feb 16, 2002
    39
  4. DigiStuff
    DigiStuff
    Jan 22, 2002
    151
    For the very best metal casing look no further than http://www.miglia.com/ Might be a few quid but very much worth it!! Build quality on these is something else, they do also do a twin drive version. Well worth the look !!!! And I don't even work for them! Never had a problem with the one I used to use at work.
    Mark T
  5. tomson
    tomson
    Jul 19, 2000
    1,918
    Berk'amsted
    +187
    Cheers folks, some useful links there.
    I've seen the Miglia stuff reviewed in macuser - really well received, but its all a bit more pricey than what i'm after.
