emp tw10h and toshiba sd150e
callipo
Just got an Epson TW10h (£468.00 from oyyy.co.uk)and all i can say is WOW.Now this is my first PJ and a budget one at that but i think the picture this piece of kit throws out is superb.
I have also purchased a Toshiba sd150e (£39.00) and was wondering if anyone could tell me what the best possible picture "setting" is.I'm a bit new to all this progressive scan and interlaced stuff.I have it connected to component.
sbowler
set the player to output progressive scan, in the set up menus and you should be sorted.
Delh68
callipo said:
Done that, but do i have to change the settings on the PJ?
Nope, if u select menu on your remote & scroll down the selections it should tell you that it is outputting @ 480P ( for NTSC) or 520P (for PAL), assuming the 150e supports both
I haven't got my Epson switched on at the mo, but i know it shows u via the remote, as long as u are getting a picture via component, & u don't have composite/s-video leads connected between the 2, then u should be seeing the best picture
Delh68
Trending threads
