EMP-810 - Crashing, Possible Clean Required?
Discussion in 'Projectors, Screens & Video Processors' started by rapid, Aug 4, 2006.
  1. rapid
    rapid
    Dec 30, 2004
    307
    Newbury
    +14
    Hello,
    We have an EMP-810 and for some reason it keeps crashing. The symptoms are as follows:
    1. switch projector on (power light changes from red to green)
    2. wait 1-10 minutes
    3. power light goes Red
    4. lamp light goes red
    Screen goes blank, remote doesn't work, controls on projector itself wont work, have to pull kettle lead to turn off.
    It was doing this for a few weeks but after pulling the power cable and putting back in we got some use out of it, then someone thought it might have been the lamp and replaced that but its got worse if anything..
    I'm thinking I might take it apart for a good clean out, would there be any harm in taking out the bulb to clearn inside casing and putting it back in etc?
    I don't really know much about projectors, so any advice is appriciated.
    Regards,
    R
