Emp 74 Xga or INFOCUS X1 ?
Discussion in 'Projectors, Screens & Video Processors' started by jjcool, Aug 23, 2004.
  1. jjcool
    jjcool
    thinking about buying one of these projectors,
    a Epson Emp 74 Xga Projector, still sealed in box £550 off a guy,
    High Brightness Mode 2000 ANSI lumens
    Low Brightness Mode 1500 ANSI lumens
    contrast 500:1
    is this a good price also is this a good projector?
    or i was thinking of buying the INFOCUS X1
    Brightness (Lumens) : 1100 ANSI
    Contrast: ANSI: **
    Full On/Off: 2000:1
    or Panasonic PT-AE 200
    Lumen 700
    contrast 700:1
    whats the best out of the 3 ?
    need some advice before buying if the Epson Emp 74 or INFOCUS X1 or Panasonic PT-AE 200
    which is best? sorry im new to projectors,
    hope someone can advize,
    thanks
  2. Crustyloafer
    Crustyloafer
    Sep 12, 2003
    9,499
    Edinburgh
    +1,236
    Personally speaking I would always buy the one with the highest contrast ratio providing all other specs are fairly similar.
  3. jjcool
    jjcool
    so i guess the INFOCUS X1 is the highest contrast ?
    i cant find the Contrast: ANSI: ** rateing on this projector
    only Full On/Off: 2000:1 whats ever that means?
    does this mean its higher than the rest?
  4. commander-vimes
    commander-vimes
    ive just purchased an emp 74 off ebay specifically because it is an xga native resolution,tried a sony es vpl1 vga(800x600) and screen door was quite visible, projector has high lumen output even in theater mode, and a relatively long life bulb and after some checking bulbs can be aquired for £175 if you look in the right places instead of £350 ish i reviewed hundreds of pj,s before deciding on that one and decided dlp was not for me with the rainbow effect, it gives me blinding head ache and i can live with the 500:1 contrast ratio which appears to be very good for an lcd pj ...going to experiment with white, silvered and grey vinyl from a sign shop stuck to a 7ft wide blackout roller blind, believe a mat grey vinyl may give best picture......jf
  5. commander-vimes
    commander-vimes
    by the way thanks to av forums for invaluable reading matter, your all stars in my book....jf:smashin:
