For Sale Emotiva XPR-5
Discussion in 'Archived Classifieds' started by Jeffp571, Jul 1, 2015.
  1. Jeffp571
    Jeffp571
    Aug 20, 2013
    3,856
    Derry
    +301
    Bought this on here a couple of months ago but plans have changed on the speakers I had in mind and I don't need this much power at the moment. I'm sure this amp needs no introduction. Its an absolute beast and will drive nearly any speaker. There is still warranty left until November 2017 which can be transferred to the new owner. This is a collection only sale. Price is firm so no offers. Full specs below.
    • Topology: Fully discrete, dual differential, high current, short signal path Class A/B amplification with Optimized Class-H™ power supply topology.
    • Number of Channels: 5
    • Power Output
      (rated power; THD < 0.1%):
      400 watts / channel (x5); all channels driven; into 8 Ohms.
      600 watts / channel (x5); all channels driven; into 4 Ohms.
      500 watts / channel (x2); two channels driven; into 8 Ohms.
      750 watts / channel (x2); two channels driven; into 4 Ohms.
      575 watts / channel (x1); one channel driven; into 8 Ohms.
      1100 watts (1 .1 kW) / channel (x1); one channel driven; into 4 Ohms.
    • Rated Power Bandwidth (at rated power; 8 Ohm load): 20 Hz to 20 kHz + /- 0.01 dB.
    • Minimum Recommended Load Impedance (each channel): 4 Ohms (which equals one 4 Ohm load or two paralleled 8 Ohm loads per channel).
    • Frequency Response: 10 Hz to 80 kHz (+ 0 / - 1 dB).
    • THD + noise: < 0.015%
    • Signal to Noise Ratio (8 Ohm load):
      > 93 dB at 1 watt (A-weighted).
      > 109 dB at rated power (A-weighted).
    • Damping Factor (8 Ohm load): > 500
    • Speaker Output Connections:
      Super heavy duty audiophile speaker binding posts - with clear acrylic insulators and heavy duty gold plated contacts; designed to accept heavy-gauge bare cables, lugs, or banana plugs.
    • Power Supply:
      3.3 kVA toroidal power transformer.
      180,000 uF of storage capacitance.
    • Input sensitivity (for rated power; 8 Ohm load): 1.875 V
    • Gain: 29 dB
    • Input Connections:
      Unbalanced (Tiffany style, audiophile quality, gold plated RCA); one per channel.
      Balanced (XLR); one per channel.
      Each input may be independently switched to either unbalanced or balanced.
    • Input Impedance:
      47 kOhms (unbalanced).
      22 kOhms (balanced).
    • Trigger:
      Trigger Input: 5 - 20 V (AC or DC); <10 mA input current required.
      Trigger Output: 12 VDC; can drive any load up to 50 mA.
    • Power Requirements: 115 VAC or 230 VAC +/- 10% @ 50 / 60 Hz (user selectable).
      The XPR-5 requires a 20 Amp circuit and standard IEC 20 Amp outlet (which is different than a 15 Amp outlet).If you don’t have a proper circuit and outlet, we recommend you have one installed by a qualified electrician.We recommend that the XPR-5 be plugged into its own dedicated 20 Amp circuit.
    • Protection: The XPR-5 is protected against excessive operating temperature, shorted speaker connections, ground faults, and other common fault conditions. If a fault occurs on one or more channels of the XPR-5, the LED above the Standby button, and the Channel Status LEDs and the LED Bargraph Meter LEDs associated with the channel that is reporting the fault will flash red. Returning the XPR-5 to Standby or switching off the AC Power will reset the protection circuitry.
    • Dimensions:
      unboxed: 17" wide x 9.5" high x 19.5" deep (includes feet and binding posts; requires additional 3-4" of depth clearance to accomodate the power cord).
      (double) boxed: 27" length x 25" width x 16" height
    • Weight: 94 lbs (net); 108 lbs (boxed)
    Price and currency: £1060 - £1000
    Delivery: Goods must be exchanged in person
    Payment method: Bank Transfer. PPG
    Advertised elsewhere?: Not advertised elsewhere
    Prefer goods collected?: I prefer the goods to be collected
    ______________________________________________________
    This message is automatically inserted in all classifieds forum threads.
    By replying to this thread you agree to abide by the trading rules detailed here.
    Please be advised, all buyers and sellers should satisfy themselves that the other party is genuine by providing the following via private conversation to each other after negotiations are complete and prior to dispatching goods and making payment:
    • Landline telephone number. Make a call to check out the area code and number are correct, too
    • Name and address including postcode
    • Valid e-mail address
    DO NOT proceed with a deal until you are completely satisfied with all details being correct. It's in your best interest to check out these details yourself.
  2. Diagnosticz
    Diagnosticz
    Jul 17, 2012
    3,346
    +903
    Hello will you definitely not deliver this
  3. Jeffp571
    Jeffp571
    Aug 20, 2013
    3,856
    Derry
    +301
    I don't want to risk sending it to be honest. I would much rather someone collected it. If you want to organise an insured courier yourself then that will be fine but I won't accept the responsibility for it in transit.
  4. Jeffp571
    Jeffp571
    Aug 20, 2013
    3,856
    Derry
    +301
  5. Diagnosticz
    Diagnosticz
    Jul 17, 2012
    3,346
    +903
    Hello Jeff i see you have added the postage price to the total, i see you paid 1k for the amp and same was paid by previous owner, and delivery price of £ 60you paid is something that in my opinion should not be included u have take a hit on delivery prices we all do, and also i see this has changed hands of ownership twice on the forums. I am not sure what the process is of changing details of ownership if its my reasonably to do this or the current owner being you to deal with that.
    regarding postage i will no doubt organize fully insured service, but its in your hands to make sure this is packaged securely with all internal Styrofoam power cable secured which i no you will just wanted to mention it. Also photos taken of the amp and packaging with dates before its sent out and with the courier driver signing document saying packing is undamaged before he collects just in case a claim has to be made. i always do this myself with all the audio gear i have sold. i just do not trust couriers. thanks
  6. Jeffp571
    Jeffp571
    Aug 20, 2013
    3,856
    Derry
    +301
    Normally I would agree with you on the postage but on this occasion I won't sell this if I have to take a hit. If someone wants it for 1060 then fine but if they don't then I will keep it. Its no odds to me. As well as that new rules state I can sell this for whatever I want so people don't necessarily have to take a hit on postage any more if they don't want to. Regarding the warranty I should be able to change that myself as the last owner did for me. I would make sure the amp was well packed for collection and plenty of photos taken in the event of a claim being made.
    Regards
  7. Jeffp571
    Jeffp571
    Aug 20, 2013
    3,856
    Derry
    +301
  8. Jeffp571
    Jeffp571
    Aug 20, 2013
    3,856
    Derry
    +301
  9. Jeffp571
    Jeffp571
    Aug 20, 2013
    3,856
    Derry
    +301
  10. Zongo
    Zongo
    Mar 12, 2012
    183
    +7
    Hi, Have the original packaging?
  11. Jeffp571
    Jeffp571
    Aug 20, 2013
    3,856
    Derry
    +301
    Yes I have the original double box packaging.
  12. Zongo
    Zongo
    Mar 12, 2012
    183
    +7
  13. Jeffp571
    Jeffp571
    Aug 20, 2013
    3,856
    Derry
    +301
  14. Jeffp571
    Jeffp571
    Aug 20, 2013
    3,856
    Derry
    +301
  15. Jeffp571
    Jeffp571
    Aug 20, 2013
    3,856
    Derry
    +301
  16. Jeffp571
    Jeffp571
    Aug 20, 2013
    3,856
    Derry
    +301
  17. Jeffp571
    Jeffp571
    Aug 20, 2013
    3,856
    Derry
    +301
  18. Jeffp571
    Jeffp571
    Aug 20, 2013
    3,856
    Derry
    +301
  19. Jeffp571
    Jeffp571
    Aug 20, 2013
    3,856
    Derry
    +301
  20. Jeffp571
    Jeffp571
    Aug 20, 2013
    3,856
    Derry
    +301
    Would be willing to trade this for a Denon AVC-A1HDA or the AVP-A1HDA.
  21. nemesis6
    nemesis6
    Jul 13, 2015
    3
    4
    Kissimmee Florida USA
    I wanted to ask if you still have the Emotiva XPR-5? I am in Kissimmee Florida in the USA. I would be willing to pay all charges associated with getting the XPR-5 delivered here. What is the price you are asking in USD? (US Dollars)
  22. Jeffp571
    Jeffp571
    Aug 20, 2013
    3,856
    Derry
    +301
    Sorry this sale is for UK and Ireland only.
  23. Jeffp571
    Jeffp571
    Aug 20, 2013
    3,856
    Derry
    +301
    Some pictures.
  24. rousetafarian
    rousetafarian
    Aug 17, 2007
    24,042
    2
    NW
    +16,077
    Unarchived at seller's request
  25. rousetafarian
    rousetafarian
    Aug 17, 2007
    24,042
    2
    NW
    +16,077
    Try again :)
  26. Jeffp571
    Jeffp571
    Aug 20, 2013
    3,856
    Derry
    +301
    Price is firm at £1000 collected.
  27. Zongo
    Zongo
    Mar 12, 2012
    183
    +7
    Hi, The most I can offer is £800 if you change your mind
  28. Jeffp571
    Jeffp571
    Aug 20, 2013
    3,856
    Derry
    +301
    Not a chance mate. I have already been offered more than that and turned it down. I won't be dropping the price.
  29. Jeffp571
    Jeffp571
    Aug 20, 2013
    3,856
    Derry
    +301
  30. kingcobbler
    kingcobbler
    Jul 27, 2004
    1,194
    48
    +61
    I wouldn't trust this beast through our postal system either! Shame you are not in England else I would take this, absolute premier beast of an amp.
    I simply (like most I guess) have the time to travel across the water.
    Daft question, but no one else has asked..... I don't suppose you ever come to England or have the spare time for a short delivery holiday?
    And on the back of this daft question I'll put a daft bid of £1100 if it was possible you could deliver it. I'm from Northampton right in the middle of England.
    Anyway, this is at least a free bump and apologies in advance for my daft idea!
