For Sale Emotiva XDA-1 DAC
Discussion in 'Archived Classifieds' started by JamesBaby, Aug 21, 2013.
  1. JamesBaby
    JamesBaby
    Nov 23, 2005
    1,185
    63
    Huddersfield
    +139
    I'm selling my Emotiva XDA-1 DAC. The sound quality through this DAC is incredible. It is a fully balanced differential design, and with a built in Pre-amp.
    I am selling it as I've changed by system to more of a home cinema system than a HiFi stereo setup and it no longer get's used.
    Item is indistinguishable from new and boxed in all original packaging, and still under transferable warranty.
    £249 delivered.:thumbsup:
    Manual with pics and specs:
    http://s273856667.onlinehome.us/emotiva/xda-1_manual.pdf
    XDA-1 Technical Specifications
    • Signal-to-Noise Ratio: > 105dB (A-Weighted)
    • Frequency Response: 5Hz - 48kHz
    • THD+N: 0.001%
    • Ground Floor Noise Level: < 15uV
    • Nominal Output Voltage: 1V RMS
    • Peak Output Voltage: > 12VRMS (balanced)
    • Sample Rate: All standard resolutions are supported up to 192kHz
    • Bit Depth: Standard bit depths up to 24Bit are supported at clock frequencies up to 192kHz
    • Inputs: 2 Optical TOSLINK, 2 COAX Digital, 1 AES/EBU, 1 USB
    • Outputs: 2 RCA (Unbalanced), 2 XLR (Balanced)
    • Internal Volume Control: Digitally controlled in increments of 0.5db
    • Remote Control: Milled Aluminum Full Function Remote Control
    • I/V conversion: Burr Brown OPA-2134
    • D/A conversion: high performance, multibit Sigma-Delta Burr Brown AD1955
    Data Directed Scrambling with high jitter immunity, and an 8x Oversampling Digital Filter
    • Fully Discrete Differential Reference™ Output Stage with fully independent balanced and
    unbalanced drive stages
    • Dimensions:
    17" wide x 2.25" high (1.75" with no feet) x 14" deep
    I have read the trading rules and agree to abide by them at all times until the transaction is concluded to the satisfaction of all parties involved : Yes.
    This message is automatically inserted in all classifieds forum threads.
    By replying to this thread you agree to abide by the trading rules detailed here.
    Please be advised, all buyers and sellers should satisfy themselves that the other party is genuine by providing the following via PM to each other after negotiations are complete and prior to dispatching goods and making payment:
    1) Landline telephone number. Make a call to check out the area code and number are correct too!
    2) Name and address including postcode
    3) Valid e-mail address (no disposable addresses such as @gmail or @yahoo for example).
    DO NOT proceed with a deal until you are completely satisfied with all details being correct. It's in your best interest to check out these details yourself.
    Also we advise that the vendor post images of the items for sale. This helps your sale by showing the condition of the goods prior to dispatch.
  2. JamesBaby
    JamesBaby
    Nov 23, 2005
    1,185
    63
    Huddersfield
    +139
    Still for sale. This epic DAC and pre-amp can outperform most AV Receiver DAC's for stereo audio.
    Will consider reasonable offers. :)
  3. JamesBaby
    JamesBaby
    Nov 23, 2005
    1,185
    63
    Huddersfield
    +139
    Bump. Still for sale. Anyone looking for a high end addition to their Stereo setup. I used this with a Squeezebox Touch and fed the digital signal to the XDA instead of using the Squeezebox's DACs. The sound was amazing. :)
  4. JamesBaby
    JamesBaby
    Nov 23, 2005
    1,185
    63
    Huddersfield
    +139
    New lower price. :)
  5. Cmoth
    Cmoth
    Apr 21, 2004
    1,156
    38
    Hertfordshire
    +22
    Do you have the bluetooth attachment?
    How long have you owened and where did you buy from?
    Ta
  6. Cmoth
    Cmoth
    Apr 21, 2004
    1,156
    38
    Hertfordshire
    +22
    ignore my earlier post, i thought it was the av processor.
    Sorry!
  7. JamesBaby
    JamesBaby
    Nov 23, 2005
    1,185
    63
    Huddersfield
    +139
    I'll move this thread to the general home cinema classifieds section, rather than Amps etc.
