Emotiva UMC 200 drop out issues with Sky?
Discussion in 'AV Pre-Amp/Processors & Power Amps' started by fayeanddavid, Apr 13, 2016.
Tags:
  1. fayeanddavid
    fayeanddavid
    Sep 23, 2009
    5,526
    Bearsted Kent
    +1,927
    Any of the Emotiva owners out there experienced this issue at all??
    I have a Sky HD 1TB box connected via HDMI to the UMC 200 and I can experience 5 or 6 dropouts per hour (sometimes more) for 1 to 5 seconds.
    Most of the time I can live with it, but not in a movie, drives me nuts, any ideas, any suggestion, jitter issues with the Sky box, process or to sensitive.....
    I've lived with this for a couple of years now and it is getting on my t..s now
    Any advice please
  2. paulst10
    paulst10
    Dec 16, 2004
    12,342
    Essex
    +1,696
    Does it only happen when the adverts cut in/out or literally during a movie?
    Also, have you tried using an optical cable and just connecting HDMI direct to the TV? There's no benefit in using HDMI over optical when using Sky/Virgin etc! so it could be worth a try
  3. fayeanddavid
    fayeanddavid
    Sep 23, 2009
    5,526
    Bearsted Kent
    +1,927
    Happens at any time, ads, movies, live sports.
    Really don't want to go HDMI to tv as I use the pre pro as a switching module for Sky, BluRay and AirPlay via AppleTV, would be a major piece of work attempting that work around also due to the current installation.
  4. rjg
    rjg
    Dec 13, 2003
    228
    28
    Winchester
    +62
  5. fayeanddavid
    fayeanddavid
    Sep 23, 2009
    5,526
    Bearsted Kent
    +1,927
    Thanks rjg, will take a look
  6. fayeanddavid
    fayeanddavid
    Sep 23, 2009
    5,526
    Bearsted Kent
    +1,927
    Pretty much says use HDMI for video and optical/coaxial for audio.
    Think I did that a while back, but can be wrong, I'll have a tinker tonight tomorrow and report back
  7. rjg
    rjg
    Dec 13, 2003
    228
    28
    Winchester
    +62
    If you set the Sky box output for HDMI to 'normal' (as opposed to DD) do you still get dropouts? If it is set to DD do you get dropouts in a programme that is entirely 2.0 without ads, e.g. a film on BBC that is stereo?
  8. fayeanddavid
    fayeanddavid
    Sep 23, 2009
    5,526
    Bearsted Kent
    +1,927
    I'll have tinker over the next day or two and get back, thanks
