thepolarbear
Is there something that you can get to do this.
I often fly more than 20 hours which means over 10h battery life
thepolarbear said:Is there something that you can get to do this.
TechnoMusic said:have you guys actually tried those you suggest?
the technet 5000 mah actually = proporta 5000mah, dual charger, same design, different brand
it said 5000 mah but they only give ard 30% charge
Sparq on the other hand 6000 mah but give 70% charge!
the hyperemic dual portable is even worse, doesn't charge with the apple USB, I manage to charge with a charge only cable, but it only give like 20% charge
hyper Mac got some higher capacity one, you should be looking at those but not the portable one
