Embedding Cables into Walls
Discussion in 'Plasma TVs Forum' started by steve 111, Jun 5, 2004.
  1. steve 111
    steve 111
    Jan 5, 2003
    558
    Newport, Gwent
    How do you embed cables into walls. I am about to move house and will be wall mounting my plasma and need to embed a VGA, component, and power cable to the plasma, and then 3 speaker cables to wall mount my Kef Eggs?
  2. hornydragon
    hornydragon
    Dec 19, 2001
    28,346
    +1,218
    various ways of doing this if it is a plaster board wall (studwork) cut the plaster board away. Brick/Block the chisel out a channel.
    Run Video and power seperately and make sure you can get cables in and out again!
  3. mralsal
    mralsal
    Steve. What type of wall are you going to be dealing with? i.e brick, stud etc
  4. jmack
    jmack
    3 cardiff boys on one thread :smashin: :smashin:
    if its brick get a angle grinder from b&q £14.99 some ready mix plaster £5.00
    if you have a look on page 26 of the get ya plasma out thread you will see how i done mine. its was easy ;) .
  5. mralsal
    mralsal
    Ok. What I did was chase out the wall which was brick with a grinder as jmack but instead of just plastering in the cables in I ran 16mm oval conduit in the wall for speaker cables. For cables going to plasma I ran 68mm round rain water down pipe with an 90 degree elbow at the top so it comes straight out of the wall at a level behind the screen. This is a good size pipe that is big enough to take the ends of even a scart lead, power cable and others pulled through it.
  6. Doctor_AB
    Doctor_AB
    Aug 30, 2003
    2,445
    48
    Buckinghamshire
    +79
    Do power and video cables need seperate channels?
  7. lynx
    lynx
    Jan 20, 2002
    4,651
    It always rains.
    +302
  8. Blu Ray
    Blu Ray
    Jun 14, 2004
    496
    Chorley, Lancs
    +12
    Doctor AB. yes, it is always best to keep the power cable separate from the other cables.
