Eltax symphony C3 centre speaker
Discussion in 'Home Cinema Speakers' started by Badger0-0, Jul 6, 2005.
  1. Badger0-0
    Badger0-0
    May 30, 2005
    20,593
    Spaghetti Junction (really)
    +1,921
    Hi guys,
    I know nothing about speakers,
    but is the above centre speaker any good??
    Richer sounds are doing this for a tenner and I thought at that price I can't go wrong, and can chuck it in the bin if it's no good :smashin:
    My current set-up is a videologic digitheatre (don't laugh, I'm not an audiophile and it sounds reasonable to me).
    Would the Eltax be an improvement over the digitheatre center?.
    Or can I make other improvements on the Digitheatre, bearing in mind I can't justify to myself spending hundreds of pounds.
    Or should I throw it and get something else??? (couple of hundred quid maybe)
    Or am I just being a total cheapskate?
    Thanks.
  2. Badger0-0
    Badger0-0
    May 30, 2005
    20,593
    +1,921
    Looks like I'm being a total cheapskate then :rotfl:
    Do you really have to spend megabucks for decent sound???
  3. Jamiroquai78
    Jamiroquai78
    I bought one today purely because it was a tenner :eek: Seemed rude not to! :devil:
    Jam
  4. brookesboy
    brookesboy
    Jun 6, 2005
    44
    How have you got on with it so far?
  5. sainthalo
    sainthalo
    Feb 24, 2005
    646
    19
    Symphony C.3 Centre
    Long Term Power
    80 Watt
    Short Term Power
    130 Watt
    System
    2 way, closed box
    Tweeter
    25mm soft dome, shielded
    Mid-range
    Woofer
    2 x 100mm, shielded
    Impedance W
    4-8 Ohm
    Sensitivity
    88 dB
    Freq Response
    60-20.000 Hz
    Cabinet Finishes
    Light Beech/Black
    Dim(HxWxD)
    145x400x185 mm
    Weight(net)
    4.5 Kg
  6. Badger0-0
    Badger0-0
    May 30, 2005
    20,593
    +1,921
    Definitely better than my Videologic centre :smashin:
    Dialogue is much clearer to my untrained ears.
    Going back to my comments about me being a cheapskate, I went out and bought another 2 to use as fronts !!! :rotfl:
    Again an improvement :smashin:
    I'm not sure if using them as fronts does anything for imaging though (although I have stood them on there sides).
    I've got a Yamaha 557 receiver coming Wednesday. I'll try that and then consider upgrading the speakers.
    Is using this model centre, or any centre as a front a mistake??
    And if so, why??? :lease:
