Eltax Spectrum 5.1 Spec change?
Discussion in 'Home Cinema Speakers' started by Blackspeech, Jan 4, 2004.
  1. Blackspeech
    Blackspeech
    Dec 14, 2002
    69
    11
    London
    All,
    Bought a spectrum set from RS - but on the back of the s/w in the shop there was a crossover freq control. Mine hasn't got one. The manual text says there is one as does the website. However the diagram does not show one. Could be just a product change, but not sure and Eltax.com doesn't say. Spec below if anyone interested.
    Subwoofer
    Sinus Max power 40 Watt
    Frequency range +/- 4 dB 45-250Hz
    Subwoofer 165mm downfiring
    Crossover Frequency 45 - 140Hz Adjustable
    Phase Changer 0 - 180°
    Volume control Yes
    Subwoofer RCA line-in Yes
    Speaker input terminals Clip
    Speaker outputs Clip
    Mains voltage 230/240V - 50/60Hz
    Power consumption stby. < 7 Watt
    On / off automatic (stby.) Yes
    Dimensions (HxWxD) 245x245x245mm
    Weight 6,0Kg
    Any input gratefully rec'd. Thanks...
  2. Blackspeech
    Blackspeech
    Dec 14, 2002
    69
    11
    London
    One sub placed in box. Spec has not changed. Went to RS again and changed. Does this ever end. Haven't had time to set up proper yet. Away until Friday. Boooooo.
    Mods please close. Thanks
