Eltax speaker systems - comments anyone?
Discussion in 'Home Cinema Speakers' started by iant, Aug 8, 2001.
  1. iant
    iant
    Aug 8, 2001
    19
    3
    Worthing
    Anyone got any comments - good or bad - about Eltax Starlight, Stargate X1 or X2 speaker systems?
  2. Markster
    Markster
    my advice forget eltax get some cheap missions instead
  3. EmissarY
    EmissarY
    Hi there,
    I've got Eltax Symphony 6.2, granted they are from Richersounds, but they sound superb for a budget set of speakers. The cheaper mission range are good too, but again they fall into the budget category. Either would be good. But don't write off Eltax solely cause they are associated with certain retail companies. They're solid cheap and good to start off with before you start to upgrade.
    Lots a luck,
    EmissarY. <img src="smile.gif" border="0"> <img src="smile.gif" border="0"> <img src="smile.gif" border="0">
  4. Guest
    Just got the Stargate 5.1 set. Well for the money, 109 quid i am quite impressed. The speakers are small and dainty, brackets, speaker wire and screws supplied (crap quality but it's free). The sub doesn't go very low though, 50hz is the lowest, but gets the job done (Top Gun sounds excellent),for the money, and if you are starting out on a low budget then i would recommend something like the Eltax, cheap, reasonable performance and build quality seems good also
  5. Guest
