Eltax Monitor 3 - would I be able to wallmount?
Discussion in 'Home Cinema Speakers' started by benskia, Jan 16, 2008.
  1. benskia
    benskia
    Feb 8, 2006
    17
    HI,
    I am looking to replace my current speakers (some very heavy Spirit Absolute Zero's) with some lighter bookshelf speakers that I can wallmount to save some space.
    Those Eltax Monitor 3's look good and are in my price range (£70), but the only problem is that they have some spiked feet on them for placing on a stand.
    Would I be able to wall mount these, or would I run into problems?
    Thanks.
  2. rcoundon
    rcoundon
    Dec 4, 2002
    152
    Basingstoke
    +6
    The spikes on the bottom are two part, both of which are removable. The first part is the spike and the second the thing that attaches the spike to the speaker base. Unscrew the spikes and remove the screw from the other part and then the speaker should be mountable.
  3. McCraque
    McCraque
    Nov 21, 2004
    317
    28
    Sussex
    +24
    problem being that the bass port is underneath the speaker....so needs to be able to breath. So keep that in mind when selecting a mount.
