Eltax Millennium Centre & Surrounds
Discussion in 'Home Cinema Speakers' started by CaRlosTHeJaCKal, Jan 21, 2002.
  1. CaRlosTHeJaCKal
    CaRlosTHeJaCKal
    Anyone any experience of these speakers? Seen them on sale at a local store for about £50 for the package. Good value? I'm on a seriously limited budget....
    BTW, running a Pioneer VSX-510 AV amp. Front speakers are Wharfedale's, but will also be changed for Eltax to match others as same shop has reasonably priced fronts too....
  2. IanB
    IanB
    Nov 1, 2001
    101
    16
    Shropshire UK
    I bought them over Christmas, along with the Millennium 150 fronts, they are my first speaker set up so unfortunately I can't compare them to anything... but I'm very happy with them. For first time or limited budget there is nothing wrong with them.
    I bought them from Miller Brothers, the whole lot cost £190 (ish).
    Hope that helps.
  3. CaRlosTHeJaCKal
    CaRlosTHeJaCKal
    Thanks for that, your opinion is valued. Just one other thing.....are the 150 fronts shielded?
  4. IanB
    IanB
    Nov 1, 2001
    101
    16
    Shropshire UK
    This is the spec, according to the Eltax website:
    Long Term Power: 90 Watt
    Short Term Power: 150 Watt
    System: 2 way Bass Reflex
    Tweeter: 25 mm soft dome
    Mid-range
    Woofer: 165 mm
    Impedance W: 4-8 Ohm
    Sensitivity: 87 dB
    Freq Response: 45-20.000 Hz
    Cabinet Finishes: Light beech / Black
    Dim(HxWxD): 750x220x235 mm
    Weight(net): 9,2 Kg
    No mention of shielding.
