Linkadventurer
Hi everyone
I have recently purchased an old Eltax liberty 712 subwoofer.
ever since I have plugged it in, Every time the subwoofer goes to standby from I get a very loud booming pop and it makes me jump through the ceiling every time. I know this can't be good for the subwoofer... Or my ceiling.
Anyway...
The subwoofer will also, still stay on 10-15 minutes after my Pioneer SC-LX 71 Reciever has been switched off and make a loud booming pop.
This also happened before I had even connected a line-in cable from the receiver to the subwoofer. I did because I wanted to make sure it would power on properly before connecting it up.
I thought this was due to the receiver and the subwoofer not being connected. Also, all connections are correct and so are the settings on my receiver.
but apparently not.
My subwoofer is set-up with the volume on 8/10 as a personal preference (my system is set up in my bedroom so its difficult to hear the bass sometimes due to the lower frequencies being absorbed by the furniture. hence the purchase of the sub as I felt the Eltax liberty speakers weren't enough on their own), I have the frequency response setting dialled the whole way up as I've been told this effectively is the same as disabling the frequency controller on the subwoofer. (my receiver is set-up to control the frequency output of the subwoofer) And phase is set to 180.(can't tell the difference between 180 or 0for the phase setting)
I would greatly appreciate if anyone could help me out with this problem as it is beginning to drive my parents and I a little spare. Also, it would be great to know if anyone else has this issue with this subwoofer, And if they have found a way of resolving the loud booming pop it does when the sub goes to standby or have any suggestion as for why this may be occurring? and any possible fixes?
Many Thanks
Christopher Sandilands
Anyway...
but apparently not.
Many Thanks
