Eltax-concept 200
Discussion in 'Home Cinema Speakers' started by john59, Oct 30, 2005.
  1. john59
    john59
    Aug 27, 2004
    398
    Wigan
    +20
  2. pragmatic
    pragmatic
    Nov 9, 2004
    12,156
    +1,647
    My mate bought some cheap floorstanders from richer sounds a few years ago and hes still using them now. The do a 16 day return polocy or soemthing, so give them a go (as i doubt you'll be able to demo them) if you keen and you can always take them back if transport is not a hassle. When using/testing look for over blown bass (typicaly boomming) and on the top end if it sounds like the singer or actor is behind a curtain then its not really very good.
  3. chedmaster
    chedmaster
    Jan 29, 2005
    2,661
    68
    +28
    try and look for some eltax liberty 5+ at richers they are in the clearance bargains and will sound better than those concept things for £10-£20 more.
  4. conkerman
    conkerman
    Feb 21, 2005
    494
    28
    +39
    I agree, Liberty's sound fantastic with a big meaty amp driving them.
    Well worth a try.
