Eltax Bargain - Can U Help
Discussion in 'Home Cinema Speakers' started by JOHNNYT, Jul 19, 2002.
  1. JOHNNYT
    JOHNNYT
    Maplin are selling Beech Eltax Milennium 300s 150w frontspeakers with a centre & rear speaker set to match for £149.99 (half price). I Don't know what these speakers sound like or if they are actually a bargain or not Can anyone help??
    Also does anyone know how much it would cost to get a matching sub and should it be active or passive?
    Cheers, Johnny
  2. lynx
    lynx
    Jan 20, 2002
    4,634
    It always rains.
    +302
    Imho Eltax are among the better budget speakers ( i still have Liberty 3+'s somewhere), although i haven't heard the ones you are referring to i would imagine that for the price they would be ok.As for a sub, look here .hth
  3. marlboroman
    marlboroman
    So did you get them????????????
    I mate at work ordered them on spec and say they look damned nice but he hasn't got a clue about how they sound or how a good set should sound......
    If you have gone for them what do you think??? Is it worth dipping a toe in and getting them? Or does any one else know somewhere cheaper..
    Let me know,
    cheers:D
