Eltax Avr-200 .....
Discussion in 'AV Receivers & Amplifiers' started by dealstokie, May 22, 2005.
  1. dealstokie
    dealstokie
    May 16, 2005
    383
    Would the Eltax be any good?
    Can get it for around £35, would it be could enough to be an entry level amp?
    Got any thoughts please.
  2. chedmaster
    chedmaster
    Jan 29, 2005
    2,661
    68
    +28
    i didn't think people looked for amps this cheap, ive never heard it but i have two old Sherwood RD-6106R's (imo a good starter amp) which i might sell! Originally paid £140 at RS for one, £80 on ebay for second, would sell for much less, if theres any interest ill put it in classifieds?
  3. Dfour
    Dfour
    Jan 19, 2004
    4,091
    71
    Bracknell
    +86
    Have only seen reviews of its bigger brother the avr800, so cant comment but for the first time amp I would recommend something entry level from on of the bigger boys like Yamaha, denon, marantz etc.
    This is the new version of the old good seller av50. Good first starter system. :smashin:
    Details
    This is a stylish AV Package that combines the RX-V357 and NS-P110.
    RX-V357 is a powerful 525W (105W x 5 DIN) 5.1-Channel Surround Sound with Quad-Field Cinema DSP and Many Other Exclusive Yamaha Features for a thoroughtly enjoyable Home Cinema experience.
    NS-P110 is a compact and complete digital home theater 5.1 Channel speaker package. A very convenient and affordable way to begin enjoying the thrilling experience of multi-channel movie sound.
    Features Click on terms for explanation.
    Convenience
    Sleep Timer
    RDS (Radio Data System) Tuner
    Auto Tracking
    Auto Power On/Off
    5 x Mode Pre-grammed Equaliser
    Sound & Power Output
    Dolby™ Pro-Logic
    Dolby™ Digital 5.1
    Dolby™ Pro-Logic 2
    DTS™ ES Matrix 6.1
    DTS™ ES
    5X90 W (RMS) Output Power
    100 W Front Speaker Output
    100 W Centre Speaker Output
    50 W Subwoofer Speaker Output
    14 x Surround Programmes
    Speaker Specification
    30Hz-25kHz Frequency Response
    6 Ohms Impedance
    86db Sensitivity (SPL)
    55 Amplifier Power Required (RMS)
    1x6" Midrange Speaker
    Connections
    3 x Component Video Connection/s
    2 x Optical Terminal Connection/s
    1 x Co-axial Digital Connection/s
    6 x Composite Video Connection/s
    3 Pair x External Speaker Connection/s
    1 x Headphone Socket
    1 x Subwoofer Pre-Out Connection/s
    6 x Front/Side AV Connection/s
    1 x Video/AUX Input
    1 x FM/AM Loop Antenna
    Accessories Supplied
    Remote Control
    User Manual
    Mains Cable
    Batteries
    Warranty Card
    Power,Weight & Dimensions
    22.5 Kg Unit Weight (Approx)
    System
    40 Station Presets Memory
