eltax avr-200 error 1 i need help
Discussion in 'AV Receivers & Amplifiers' started by andrew anderson, Mar 16, 2006.
  1. andrew anderson
    andrew anderson
    i have a eltax arv-200 integrated amp and its is showing error 1
    wot can i do to put this rite :lease:
  2. Garrett
    Garrett
    Apr 21, 2001
    44,821
    2
    167
    The best thief you'll never see.
    +9,074
    Moved from GC.
  3. juglandblues
    juglandblues
    Mar 19, 2006
    273
    +15
    I have the same problem Andrew. I stuck mine in a cupboard for a few months and tried turning it on this week just to see. It worked for a few seconds then nothing. From a foreign site i was looking at it seems the problem is a resistor on the board and theres no quick fix. Eltax emailed me aswell but they were no help and said it needed sent away. Cant see it being cost effective to fix it so im just gonna bin mine and buy another one.
