Eltax Atomic A-6.2
Discussion in 'Home Cinema Speakers' started by Steveb, Jan 26, 2003.
  1. Steveb
    Steveb
    Hi all,
    I've recently aquired the above sub and am using it with a Pioneer VSX-C100 receiver. The sub only seems to have an auto on /off setting and I am having a problem with it not coming on unless the volume is quite high. If I try to watch anything late at night with low volume then the sub goes off which is annoying as it is still required at my listening volume. Are there any setting I can set on the amp to try to force a stronger signal to the sub to make it wake up?
    I've got the speakers set to small and everything including LFE is sent to the sub. I've also tried turning on sbass. Should I turn the amp volume right up for the sub maybe?
    Steve
  2. Tom_1234
    Tom_1234
    Jun 22, 2008
    17
    3
    +3
    probally to late to answer now but try putting the speakers directly to the amp and the sub input to the amp and turn up the volume. i have the same sub and that how ive set it up
