Eltax 10.2 Is it worth £100????
Discussion in 'Home Cinema Speakers' started by nictry, Jan 24, 2004.
  1. nictry
    nictry
    Apr 28, 2002
    5,759
    Kent
    +645
    Looking to add a sub to my system (not going mad as first time) have a possible second hand deal going for around 100 but looking about the price of the 10.2 Eltax seems to be approx 150-200, have come across one brand new for £100 is this a good val sub for this money????
    Any help appreciated, I know that I should be spending lots more to get a cracking system but that is about all I can go to right now :rolleyes:
  2. krusty
    krusty
    if your budget can stretch a bit...the VELODYNE VX10, is [ i think] 200 pounds and will wipe the floor with your original choice.
  3. Ian J
    Ian J
    Aug 6, 2001
    25,628
    +4,905
    Personally I wouldn't buy the Eltax but would buy something better second hand. There are some quite good Paradigm PDR subs that come up in the classified forum but unfortunately they are like buses and you see none for ages then loads come on the market at once.
  4. nictry
    nictry
    Apr 28, 2002
    5,759
    Kent
    +645
    I think I will go with your advice, there is a Jamo SW505 that seems to offer the sort of comparison to the Paradigm etc. (at least the reviews seem to suggest that)
  5. Ian J
    Ian J
    Aug 6, 2001
    25,628
    +4,905
    I see that you've bought the Jamo and I'm sure that you won't be disappointed.
  6. nictry
    nictry
    Apr 28, 2002
    5,759
    Kent
    +645
    Yep, looked like a pretty good sub and worth the money (although it is a pretty hefty size!!!)
