Elonex Artisan config problems
Discussion in 'Desktop & Laptop Computers Forum' started by _Dom_, Mar 17, 2005.
  1. _Dom_
    _Dom_
    Feb 20, 2005
    114
    Thought i'd start a thread for this.
    As such I will kick off !
    I'm trying to get mce to scan my tv stations but it can't find any.
    I have the aerial lead from the wall going into my sky box, the rf out from the sky to the input rf on the artisan and the out rf on the artisan to the tv.
    But when I do that the tv can't see any channels ! Must I connect another lead from my sky box to the artisan ?
    The aerial leads are fine as I tried connecting them direct to the tv and they work.
    I wondered if i needed to install some drivers but looking at device manager I can see the Hauppage TV tuners there. Any ideas please ?
    cheers
  2. _Dom_
    _Dom_
    Feb 20, 2005
    114
    actually, got the tv working from the sky input ok now.
    Now how do I set it up so I can watch another channel whilst recording on sky ? :lease:
    I think i need to configure the other tuner but i don't know how as it seems to not recognise rf input
    cheers
  3. CTID
    CTID
    Dec 28, 2003
    726
    Far, Far Away
    +16
    unless the other input is sky you can't. Both inputs have to be the same, so its another sky box or forgot it.
  4. _Dom_
    _Dom_
    Feb 20, 2005
    114
    so is there any point in connecting the rf leads to the skybox/artisan ?
    can't i just connect my aerial straight to the tv then at least i could watch terrestrial channels whilst recording something ?
  5. CTID
    CTID
    Dec 28, 2003
    726
    Far, Far Away
    +16
    not really. Put the RF in your telly and leave the dms talking straight to the sky box. If you put the RF into the artisan when you set up the dual tuner it will just say the sources are different and ignore one.
  6. _Dom_
    _Dom_
    Feb 20, 2005
    114
    I have a fw albums on my hdd and I added a couple to the media centre using the wizard. But now when I go back into My Music there seems to be no option for adding any again ! I know I can add from the cd but I want to add directly from the HDD as i am migrating my stuff from my old pc to this one. Any ideas ? :lease:
    cheers
  7. _Dom_
    _Dom_
    Feb 20, 2005
    114
    found out - u press the more info button on remote. I would have thought there would be help/instructions for this somewhere (ideally within mce itself) - can't find any though - if someone know of a resource that has this kind of info i would aooreciate knowing where it is - it save having to trawl thru forums at TGB !
    cheers
  8. jonsayers
    jonsayers
    you can also right click to bring up that menu.
  9. jonsayers
    jonsayers
    LOL also See Page 88 of the manual "You may add any additional folders by using the mouse and right clicking on the screen and choosing "Add Folders" :p
  10. _Dom_
    _Dom_
    Feb 20, 2005
    114
    ah .... think my eyes need testing.
    cheers
