Ellion DVR-515A
Discussion in 'Blu-ray & DVD Player Multiregion Hacks' started by zedman, Jan 24, 2005.
  1. zedman
    zedman
    Does anyone know of any hacks for the
    Ellion DVR-515A recorder please ;)
  2. Damian1978
    Damian1978
    Jul 15, 2000
    4,488
    107
    Fleetwood, Lancashire
    +265
    Multiregional
    · Ensure tray is closed, and in "No Disk" mode
    · Enter: 77 on the Remote Control
    · You can now either select the required region/country manually, by pressing the numbers on the remote
    · (To enable multiregion - select region "0")
    · Select Enter to exit Menu
    How's the recorder?
    Does it have an RGB input, Videoplus (PDC) and NICAM tuner?
    Damian
  3. zedman
    zedman
    Thanks for that, dunno re your Q's. This machine was just a consideration, not bought one yet? ta :thumbsup:
