Ellion-515A multiregion hack
Discussion in 'Blu-ray & DVD Player Multiregion Hacks' started by GorFen, Mar 25, 2005.
  1. GorFen
    GorFen
    I found the following hack for the above, yet following the instructions nothing happens on entering 77 (no menu appears)
    Ensure tray is closed,and in "No Disk" mode
    Enter: 77 on the remote control
    You can now either select the required region/country manually,by pressing the numbers on the remote
    To enable multiregion- select region "0"
    Select Enter to exit menu
    Has this worked for anybody else with this recorder?
    If so what am I doing wrong?
    Thanks for any help
    Gordon
