Elite using hdmi to Dvi
Discussion in 'Xbox Forums' started by Gazaman, Sep 7, 2007.
  1. Gazaman
    Gazaman
    Jun 22, 2007
    2,000
    Chesterfield
    +178
    I recently started a thread about problems connecting my 360 premium to my tv using VGA http://www.avforums.com/forums/showthread.php?p=5437556#post5437556
    However...........my 360 was in fact faulty and i have since changed to an elite.........which brings me to my next questions(sorry)
    As far as i am aware DVI is exactly the same as hdmi but cant send audio so after setting up my elite using the hdmi-to-dvi lead i was expecting to get th hi-def options (720p,1080i,1080p etc) but i was only offered the option of changing the actual resolution as if i was using a vga lead,is this correct??
    If not could it be because of the lead that i bought which was a HDMI to DVI-D SINGLE LINK?
    Since buying the above cable i have had a look on the internet and it seems that the best dvi lead to get would be a DVI-I dual link.
    One more thing.....when i tried to put a game in earlier it says it couldn't play it because it was PAL-50 (or it could have been 60,cant remember) and to change this setting in the display options,but there is no such option.
    Please help
    Gary
  2. Gazaman
    Gazaman
    Jun 22, 2007
    2,000
    Chesterfield
    +178
    Forget about the Pal bit at the end cos i've managed to sort that:cool:
    Gaz
  3. SHPanda
    SHPanda
    Dec 9, 2006
    152
    +6
    I don't really see a problem. Can't you just choose the resolution that is 720p or 1080i/p whichever you want? I'm sure they'll be in the list.
  4. Munkey Boy
    Munkey Boy
    Nov 23, 2003
    16,960
    2
    2
    Manchester
    +4,473
    720 & 1080 are just shortened resolution references.
    720 = 1280x720.
    1080 = 1920x1080.
    It doesn't really matter which format they're referenced in does it?
  5. Gazaman
    Gazaman
    Jun 22, 2007
    2,000
    Chesterfield
    +178
    I actually wondered about this but(as i'm sure you've worked out yourself by now) i know absolutely jack sh*t about all this.
    I thought that if i was not getting the format options then maybe the 360 is not recognising my tv as being hd therefore not sending an hd signal.
    This is probably completely wrong but i'm trying to get to understand how this connectivity works.
    Gary
  6. Munkey Boy
    Munkey Boy
    Nov 23, 2003
    16,960
    2
    2
    Manchester
    +4,473
    No worries - we're all new to this at some point! The only thing to remember is the option to display at 1920x1080 is identical to the option to display at 1080p - both are HD options, just as 1280x720 is the same as 720p.
    There's some useful info in the FAQ you may want to see too...
  7. Blackbolt360
    Blackbolt360
    Sep 28, 2006
    1,793
    116
    Cheshire
    +794
    All resolution numbers just refer to the vertical resolution. Just remember that every number is associated to the vertical aspect, 60hz = 60 Vertical Hertz, 720p = 720 Vertical Lines Progressive.
  8. Gazaman
    Gazaman
    Jun 22, 2007
    2,000
    Chesterfield
    +178
    Thanks alot for your help guys (much appreciated) but was wondering--do i set my 360 display settings to native res or max supported res(1080i)?????
    Gaz
