Johnmcl7
(apologies if this should go in one of the TV forums, seems more like an issue with the Elite so I thought I'd start here)
Hey folks, having a problem with the hdmi connection on my Elite - whenever there is a dark scene, the previous data is imprinted on it. Sort of like really, really bad ghosting except it doesn't disappear it just sticks there. I noticed some issues with Bullet Witch but didn't pay much attention as it doesn't have many dark scenes. However playing Bioshock it's very noticeable and very annoying. The WB is out in these shots but it highlights the issue, this is taken in the lift down - I've spun around from the bright door then hit the pause button and you can see it's all still there:
Again in the lift, I've turned again and you can see the lit joint has left a trail:
And one just outside the lift, you can see as I've moved it's created the effect in the dark area:
This is the first time I've used the hdmi socket on the TV, I can't remember the exact model number but it's the 32 inch Samsung LCD that was released around the time of the original 360. It looks to work fine on all other inputs (been using a Premium over component pretty much since launch), it's just hdmi that seems to be the issue.
I do have another slightly newer Samsung TV with hdmi, I plan on moving the Elite through and trying it on that but would appreciate any thoughts people have. Incidentally, the moment I power down the 360 and the TV returns to a black screen it's a solid black - no persistance there. Also, this is not standard burn-in/image persistance as it disappears when something else overwrites it.
Any thoughts appreciated, none too happy right now.
John
John
