Question Elexa not responding
Discussion in 'Smart Home, Climate Control & Security Forum' started by HarveysS, Jan 6, 2018.
  1. HarveysS
    HarveysS
    Jan 4, 2018
    11
    GB
    Hi all, all my Sonoffs are working in that I have constant green LED and they work with E-welink app. The elexa app also works and my devices are set up and the E-welink skill is enabled. Each device is named the same in both apps.
    When I ask elexa to turn something on/off, it replies sorry "" "" is not responding. It was working earlier this evening so I don't know what's changed.
    The sonoffs did drop connection earlier which I believe is due to the Itead server being overwhelmed by additional units sold at Xmas. Do anyone think this could be the issue, or does anyone have an opinion?
    I have noticed in the E-welink app, under settings it states "flourite account not bound yet" . I have no idea what this is or if relevant. My wifi is set to 2.4ghz as well.
    This has happened before but it's annoying.
    Any advice would be appreciated.
  2. limegreenzx
    limegreenzx
    Feb 9, 2006
    2,018
    +337
    Alexa IS responding. It is the Sonoff service that is not responding. You are 100% reliant on a 2 cloud services for functionality.
  3. HarveysS
    HarveysS
    Jan 4, 2018
    11
    GB
    I would agree but the sonoffs are working fine via the app. Does anyone have any suggestions please?
  4. giffordpikes
    giffordpikes
    Jul 16, 2017
    251
    46
    Wiltshire, uk
    +174
    I don’t use sonoff but I had a similar problem when my Sonos speakers stopped responding to commands following a series of power cuts. I got it to work again by disabling the skill then reconnecting. By reconnecting the accounts it seemed to do the trick. You could try that if you haven’t already got it working.
  5. HarveysS
    HarveysS
    Jan 4, 2018
    11
    GB
    It came back on by itself and worked for a few days, then this morning off again. I think it may be the Itead server which is being updated and will be completed mid Jan. I'll wait until then to see if the problem persists
  6. chriszzzzzz
    chriszzzzzz
    Jun 19, 2005
    1,099
    Coventry
    +83
    She might have been a bit sniffy because you called her Elexa..??;);)
