shotokan101
I found this quite useful From DPReview :-
Electronic shutter, rolling shutter and flash: what you need to know
Jim
Jim
Yep good article that Jim. Whilst I am actually familiar with everything it that article it's handy to have it all in one place and a good referenceI found this quite useful From DPReview :-
Jim
We will have to wait and see. I also though banding was determined by the frequency of light, 50hz or 60hz depending on whether in the US or UK (50hz in the UK IIRC). Apparently if you make sure your shutter in i multiples of the same frequency ie 1/50, 1/100, 1/150 in the UK it should avoid the issue, although I've not tried this myself. The trouble with the electronic shutter is that you cannot change the readout rate so if it doesn't match the light frequency you're in trouble. However, you do have the mechanical shutter for such situations.It was a good read. I'm wondering just how much better the Sony a9 will be at coping with things like rolling shutter and possibly even banding from indoor lighting.
Yeah... I read about frequencies Snerks... there's no way on earth I'll get remember to set the right speed for fluorescent lights etc - If electronic shutters don't play nicely with indoor lights then you lose the advantage of having a 'silent' camera... I may as well stick to traditional DSLRs if that's the case.We will have to wait and see. I also though banding was determined by the frequency of light, 50hz or 60hz depending on whether in the US or UK (50hz in the UK IIRC). Apparently if you make sure your shutter in i multiples of the same frequency ie 1/50, 1/100, 1/150 in the UK it should avoid the issue, although I've not tried this myself. The trouble with the electronic shutter is that you cannot change the readout rate so if it doesn't match the light frequency you're in trouble. However, you do have the mechanical shutter for such situations.
But as I said you have the mechanical shutter on the A9 as well, then silent shooting for the rest of the time. In reality how often are you going to run into the fluorescent light issue?Yeah... I read about frequencies Snerks... there's no way on earth I'll get remember to set the right speed for fluorescent lights etc - If electronic shutters don't play nicely with indoor lights then you lose the advantage of having a 'silent' camera... I may as well stick to traditional DSLRs if that's the case.
People play down the advantage of silent shooting - I don't - I think it's a huge positive factor for discrete work that doesn't break the emotion of the 'moment'.
Shutter speed defines the intensity of the banding
Given we use 50Hz in the UK and Europe I just need to avoid shutter speeds of under 1/100th under strip lights and LED without additional flash. Given the cameras I have I think I'll be OKThis is only a problem if your shutter speed is short, though. If your shutter speed is longer than one flicker cycle (a light and dark period), shouldn't see any banding because the exposure will be long enough to average-out the flicker of the lights. But, as you use shutter speeds faster than one cycle (typically 1/120th of a second under most lighting on 60Hz power), you'll begin to see banding.
