Electronic drum kit - relocate to garage?
Discussion in 'Pro Audio and Musicians Forum' started by the_jinj, Jan 10, 2012.
  1. the_jinj
    the_jinj
    Aug 1, 2005
    1,080
    Glasgow
    +95
    Does anyone have their kit in a shed/garage? I'm thinking of moving my DTXplorer to the garage but not sure if it's a wise idea. May even build a small insulated room within with a tube heater or similar to keep things heated....
  2. Toasty
    Toasty
    Jun 11, 2004
    12,641
    167
    Staffs
    +4,009
    Well, this isn't the best comparison, but our guitar hero drum kit was left in the garage and the puny lead for the bass pedal has disintegrated. I's say only put it in a garage if it was well sealed from the elements, ours isn't.
  3. duncfunk
    duncfunk
    May 8, 2009
    2,311
    +452
    Would definitely need to be insulated I'd say. Condensaton from cold nights wouldn't be good for all of the electronics inside the module or any connections to the kit.
