electrohome ecp3100 fault
Discussion in 'Projectors, Screens & Video Processors' started by micksahippy, Sep 3, 2005.
  1. micksahippy
    micksahippy
    i have a problem with my pj, it was working ok until my brother cracked the front glass on the blue tube. .
    i have now replaced the glass, i removed the tube to do this but now when i try to power it up it seems to be ignoring the remote control,it will eventually come to life,fans running but no way can i get any light from any of the tubes.
    the projector had no power at all for about three weeks.
    any ideas?
    thanks in advance.
  2. bxd
    bxd
    Oct 17, 2001
    1,487
    Southampton
    +134
    In your efforts to remove/replace the tube you may have upset the board connections. You might try removing all of the boards (one at a time) and then replacing them 'firmly' back into their slots.
    You might want to replace your brother as well !!
    Welcome to the forums,
    Brian
  3. micksahippy
    micksahippy
    i'll give it a go , but i don't think my mum will be happy :)
