Electrical fault while idling (ford Focus C-Max 2.0L TDCI)
Discussion in 'Motoring' started by isak, Aug 28, 2013.
  1. isak
    isak
    Jun 4, 2013
    43
    9
    Hi all
    Never expierenced such an issue!!! I had a problem with my EGR valve and been to garage which confirmed its the issue by plugging in a diagnostics tool but several months later my car started to idle badly and after some fault finding i noticed when i turn my aircon/radio off before i start the car its fine?????! Turn the car off with radio or fan on then issue is back again!!!
    What can this be??? Its a Ford Focus C-Max 2.0L TDCI 54 plate
  2. isak
    isak
    Jun 4, 2013
    43
    9
    The car wont idle more than 2000rpm but after awhile with smoke (grey) coming from exhaust then with foot slightly on pedal it will regain reffs????
  3. Simian Sibling
    Simian Sibling
    Jan 18, 2005
    6,579
    Brentwood, Essex
    +1,181
    Could be an injector? I had one go and I got a ruff idle. Get it pugged in again and that should tell you?
  4. isak
    isak
    Jun 4, 2013
    43
    9
    Thanks, it was my EGR and sensors as im still in the cleaning process. Will use EGR cleaner soon
