Electric Tab Tensioned Screens
colinstone
Well, my current grey screen is pretty flat in the centre, but edges are seriously curled. It is basically just a window blind mechanism with a 2m wide piece of Harkness light grey screen material, recommended for DLPs in early 2000s, with the bottom bar filled with lead shot to weight it down. Probably too much which is why screen edges are curved!!
Now looking at getting a white screen for Sony 320ES. Looking at 3 options:
Luxburg 100" 221cm view width -- case 254cm W. Gain 1.0. Seems to be amazingly cheap - £236.
Celexon 100" 220cm view width - case 251cm W. Gain 0.9. Middle value. £630. Best for screen width/case width ratio
Sapphire 92" 203cm view width - case 249cm W. Gain 1.1 and claims "micro diamond optical grooves". Most expensive. £912. Case really too wide for screen width.
Sapphire 92" 234cm view width - case 284cm W. Gain 1.1 and claims "micro diamond optical grooves". Again expensive. £1000. Again case really too wide for screen width.
Seems that Celexon is a good solution. I can get extra screen width for just about the same case size at the Sapphire 203m.
Any comments??
