Electric Shock from Xbox - Help
Discussion in 'Xbox Forums' started by sgmess, Jan 14, 2005.
  1. sgmess
    sgmess
    Jan 5, 2005
    4
    On reconnecting my crystal xbox to my AV setup yesterday, I was holding the end of the audio plug on the standard AV lead and touched my PC case which gave me a slight shock, all equipment was plugged in but turned off. I was slightly surprised so I got out a voltmeter and connected it between the outside connector of the red audio plug and my PC case (Therefore grounded). It measured a voltage of about 115 volts AC. I also tested other connectors and found this voltage on both Audio plugs inside and outside contacts and the composite video connector.
    I note the xbox is double insulated but can not believe this is normal behaviour, can anyone confirm this voltage should be seen on these contacts and if not what possible damage could this have caused to other connected equipment?
    Many thanks in advance
  2. Mr.D
    Mr.D
    Jul 14, 2000
    11,167
    +1,209
    PC case probably just grounded the audio signal and gave you a little shock , tiny current (otherwise you'd be dead!) You get this on quite a few bits of kit.
    Sometimes touching a case will give you a shock if you've gotten a big enough static charge on yourself. Its not that the kit has shocked you , its merely earthed the charge.
    Most modern kit will shutdown if there is any serious short going on. And its rare for there to be deadly levels available inside the case outside the PSU which are normally quite well sealed. You can still get a nasty shock and burn from certain bits of kit though so its not an invitation to go poking around inside. Just means the risk of instantaneous death is quite small. CRTs can be quite dangerous though even when they are unplugged.
  3. wmevius
    wmevius
    I had exactly the same experience: the scart connector gave me the shock, and it's showing as 115 volts compared to ground (in the socket) and real earth.
    It's only showing 115 volts when plugged in (even without the unit being switched on). I tried different sockets, in different buildings with the same result.
    I understand that the current must be low (although I was wearing rubber soled shoes at the time), but surely this can't be normal? Wouldn't it be dangerous for someone with a pacemaker for instance?
