Electric Screen that opens UPwards?
Status
Not open for further replies.
Mark Ward
I've recently bought a Barco BG801s as my first CRT. I need an 8ft screen that can open upwards. They idea is to fix it under this window
Any other suggestions/solutions also gratefully received.
Also what gain would be recommended for this PJ. I'm confident I can get the room pretty dark.
Thanks for any ideas,
Mark.
Matinee
Well, it's possible, but you do realise you'll pay through the nose for it ? (No idea of price, but I'd be amazed if you found anything for less than a couple of grand, probably looking at double that or more)
You'll be much better going for a manual screen, with a folding hook on the window. Why cant the screen go on one of the walls instead?
PK
nfordenfield
Mark,
Order an electric one from Oz and turn it up the wrong way when back in blighty !?!?!?!?!
Sorry could not resist that one.
Rgds
Nathan
marcoeser
Established Member
Hi Mark,
I still don't see how you'll block off the top part pf the triangle part of the window. Putting in a screen as you suggest won't solve the problem.
One idea I can think of is black out top window panes of the triangle with black paint and then hang the screen from the top in front of the window...see attached
marc :rolleyes:
Mark Ward
Hi Marc
I planned to do this but with blackout plastic panels held in with tape. Seems a bit more reversable than paint. I'll run blinds for the lower parts and the screen will go in front of the blinds.
Mark.
X3ELS
Established Member
Stewart do a screen that does exactly what you are after but they are VERY expensive.....
However they are awesome screens, nothing better.
Status
⭐ Philips OLED+908 TV preview + REL subwoofer and Avid Accent amplifier reviews + Hi-Fi & AV News
Back
