Electric Screen Problem
Discussion in 'Projectors, Screens & Video Processors' started by figlio, Oct 24, 2004.
  1. figlio
    figlio
    Dec 17, 2002
    180
    Malta
    Can you help me please?
    I have just bought a second hand 8 feet electric screen (projecta 4x3). It was only 15 months old.
    I bought this screen in immaculate condition with no warping at all. After I installed it at my house it was still good with no warping (as I got it).
    Projecta screens come with a white rod at the bottom of the screen and I wanted to cover this in black. So I bought some black velvet contact paper, slid the bottom rod out. I covered it with this contact paper and put it back.
    Now, I have noticing that the screen is not flat any more, especially the first 10 inches from the bottom. Is there something I can do, to remove this wrapping?
    I am not sure if the problem is indeed the contact paper.
    The screen is on a wall on the upper floor about 2 feet down from the ceiling and there is a skylight, but the sun does not go direct on the sceren. I live in a hot country were temperatures inside the house without air conditioner can reach even 30c. Is it possible that this wrapping came from the heat and not because I removed the rod at put it back?
    I can keep the screen unrolled, would it be better to remove or reduce the wrapping?
    Please help me because I feel frustrated with this problem. I thank you very much for your kind assistance.
    Best Regards to all.
    :lease:
  2. FTP
    FTP
    Ara!!! Int hawn ukoll Filjozz? Ma kontx naf li dilettant ta' Home Cinema ukoll int!! Ghax kieku ilni ndejjqek ghax jien dilettant kbir ukoll.
    Dejjem jekk int l-istess Figlio li naf jien.
  3. loonatic
    loonatic
    Jan 4, 2003
    1,925
    41
    Springwell Village, Gateshead
    +16
    I couldn't have put it better myself :rolleyes:
    Did the warping occur directly after you replaced the bottom bar ? did it get stretched when you removed/replaced it ?
    Cheers, Lee
