Looking for some advice on electric radiators.
I am going to be using a Cabin in the garden as a Home Cinema - this will be a dedicated space using a projector.
As it is at the bottom of the garden there is no Central Heating - at the moment the electric radiators in there are gloss white...
With the aim of keeping warm but minimising reflections I am hoping to fit radiators that are painted matt black (or similar). Am looking for advice on a few points:
1) Any experience/recommendation for sourcing electric radiators that are already matt black ? I am not sure painting a already gloss radiator will work that well.
2) Placement - if matt black would 2 radiators be best on one of the following (in terms of reflection)
a) on the wall next to the screen (one each side around a foot away from screen edge)
b) the opposite end of the room facing the screen
c) on the 'side walls' around the centre (roughly in the middle of the room), circa 2 to 3 m away from the screen
c) is where I initially planned but am worried this could rebound light?
All advice welcome!
All advice welcome!
