DJT75
We have a new(ish) 26 sqm gazebo in our garden (7.2m x 3,6m). One of the king sides is pretty much up against the house and the other 3 sides have pull down blinds.
I was hoping to get wall mounted heaters for it but they can’t be fitted on any of the sides with blinds, and we’ve not got enough spare brickwork around doors/windows to fix them to the house, so I’m looking at freestanding electric infa-red heaters. Ideally I’m after the column type (1 metre high type) not the overhead on stand type).
Reviews are so mixed from not giving out the heat they claim to absolutely horrifying pictures of gutted gardens due to electrical faults (that’s one of the top rated on Amazon).
Looking at just getting one initially, it can be moved/rotated to whether people are sitting on the sofa or at the table. Might invest in a 2nd if impressed.
So what outdoor heating do you have and/or can recommend?
Picture of our set up if it helps, and also an example of the sort of thing I’m talking about.
Seems we probably need something that can get up to 2000W.
