philip5660
Established Member
I'm trying to find a very low and wide electric fire that I can slot in under my TV as low as possible that will also give me room for a recessed centre speaker .
So far I've found :
Gotham 1300
Gazco 135r
Both of which would be a tight fit due to the gubbins behind the wall which you don't actually see.
Not worried about heat. It's for aesthetics. There's a projector screen in play here as well, so bottom of that is about 660mm from the floor.
Anyone got any other ideas?
So far I've found :
Gotham 1300
Gazco 135r
