Hi all,
I'm looking to upgrade my front speakers and am really interested in Elac speakers, they sound - also in the lows - and look amazing (especially with JET tweeters). However, I am a bit confused about which types of speakers might fit my current set up best. Perhaps you have some suggestions, I'm mostly interested in older models so that I might find them second-hand.
Intended 4.1 setup:
Amplifier: Yamaha RX-V477 - rated for 6ohm 80W speakers
Subwoofer: Yamaha MS50DR 50W 8 inch woofer
Rear: 2x Jamo D110 (70W RMS, 4~8ohm) - currently used as fronts
Front: 2x to be found!
Mainly used for music (cross stereo) but also regular cinematic evenings.
Some options I have explored
1. Elac BS 423.1 423.2 or 423.3
Impedance 4ohm - minimal 3.6ohm
Sensitivity 88dB
Would my receiver be able to power these speakers comfortably? I sometimes do listen to higher volumes.
2. Elac BS 423.4 (newest revision)
Impedance 6ohm - minimal 4.8ohm
Sensivity 85dB
Impedance seems better suitable, but they decreased the sensitivy. Would these speakers be harder to power for my not extremely powerful receiver? Or similar to the prior revisions (1)? I would probably only be able to purchase these new at this stage, so not my preferred option
3. Elac BS 203
Impedance 4ohm - minimal 3.5ohm
Sensitivity 86db
I guess option 1 is better suitable
Other requirements
Intended 4.1 setup:
Sensitivity 88dB
Sensivity 85dB
3. Elac BS 203
Sensitivity 86db
Other requirements
- I would like to drive the front speakers also with low frequencies (set up as "Large" speakers or set crossover value really low), because my subwoofer doesn't cover many frequencies, as it's not built for a hifi set up but gives a nice boost nonetheless.
- For us it's very important what the speakers look like, as we want them to be one with our interior. Jamo D110 have quite a unique industrial vibe, so we are looking for something that is not entirely different.
- Black Elac speakers with JET tweeters and/or crystal cones look amazing for instance. Other speakers that have some AMT tweeter - or similar details - would probably also look fine!
- Furthermore, ideally I want to keep using the speaker stands I have, which means I cannot have speakers with a depth of more than ~24cm/9.5 inch. But this is not necessarily a hard requirement
