ELAC Cinema XL
Discussion in 'Home Cinema Speakers' started by gtfc, Jan 24, 2003.
  1. gtfc
    gtfc
    HI,
    Could anyone please help with the following.
    I keep seeing v good reviews for the Elac Cinema 1 package, but I know they do a Cinema XL set which uses the same sub with the better Cinema 2 sats and a proper dual cone center speaker. Does anybody have any knowledge or experience of the XL set which will help me make an informed choice over what to buy.
    I can get the Cinema 1 for 350
    Cinema 2 for 399
    Cineam XL 429
    Thanks in advance
  2. neilybealy
    neilybealy
    Jul 9, 2001
    1,556
    48
    Kent
    +57
  3. Hinch
    Hinch
    Sorry neilybealy I can't answer your question but I'd like to know where your getting the Cinema XL from and do they do the Pipe front speakers as well?
    Sounds like youve narrowed it down to Elac. Have you had any thoughts on the Mission FS1's. They are in the same price bracket as the ones you list. I'm going to audition some Missions as well as the Elacs to see what they sound like.
  4. gtfc
    gtfc
    Hifistore.co.uk are getting some in soon, I only found out about the XL set on the German Elac Website. Senheiser who import them list them on a price list but don't feature them on their site. It just shows what a limited amount of product is reviewed by UK magazines.
    Regards
    John
  5. gtfc
    gtfc
    If you look at WWW.Elac.com you may find what you're looking for. I've heard the missions against an Elac Cinema 2 and the Elacs win on sound and look much much better. + they have a 10 warranty !!
    Regards
    John
  6. Ade
    Ade
    Jan 11, 2003
    146
    Ayrshire, Scotland
    +9
    Hinch
    Found Cinema XL at proaudiosystems.co.uk (also sells Cinema 1,2,XL components separately). Don't know about Pipe speakers though.
    Did you audition the Elacs?
  7. Hinch
    Hinch
    Yes you could say I narrowed it down to the point where I purchased the Elac Cinema XL system (Cinema 2's with the XL centre and the 101 sub) I picked them up last week and I am very impressed. I auditioned the Mission's but took a chance on the Elac without listening to them and it paid off....Phew :)
    Very robust speakers and sub is nice as well. I married them up with QED silver aniversary cable to fronts and centre and QED copper to rears.
    So far movies sound excellent and cd's are good too. Cant comment on DVD Audio or SACD as I havent had chance to purchase any yet. Anyway my verdict is damn good system for £550.00
    Ian
    Panasonic 37PW5B, Onkyo SR600, Pioneer 656A, Freeview and of course Elac sub/sat
  8. kwangomango
    kwangomango
    Jan 9, 2003
    859
    Kent
    +38
    Cinema XL is reviewed in this months What HiFi. Gets 3 stars i think. They say that the Cinema 2 speakers are not as good as the 1's
  9. Dubbing Mixer
    Dubbing Mixer
    Jan 27, 2002
    643
    By, and sometimes in, the sea
    That fits with the quick audition I had in less than perfect circumstances. I thought the 1's were much better integrated and less 'shouty'.
    I'm seriously thinking about getting a set for the sitting room. (WAF) ;-) Bit of a comedown from the main listening room but a lot better than nothing and I can't afford a set of Gallos
