elac cinema 1
Discussion in 'Home Cinema Speakers' started by dubledene, Jun 9, 2005.
  1. dubledene
    dubledene
    hi chaps been looking at these as a change to my mission fs1 7.1 speakers, does any one own them are they any good, and i presume that everything is ran from the amp ??? so in theory i could get hold of an extra 2 satalites for 7.1
  2. pcookie
    pcookie
    Mar 27, 2002
    428
    +20
    Yes you can.
    I have a set running with a (non buzzing!) Sony 795 and for Home Cinema they are fine. For music they are not, but for the money you're not going to get musicality.
    Also their positioning will be a lot more critical than the FS1. If you want an improvement over your Missions, I would say you need to look further up the gene pool to the likes of KEF eggs etc.
    cookie
