ELAC Cinema 1 CM ?
Discussion in 'Home Cinema Speakers' started by mikemod, Dec 5, 2003.
  1. mikemod
    mikemod
    Dec 2, 2003
    9
    3
    Just bought the Elac Cinema 1 package.
    I am reasonably pleased but the system is definitely a bit tinny on Sky in PLII mode. Seems OK in DTS or DD5.1
    Has anybody seen the Cinema 1 CM centre speaker mentioned in the Elac site for sale in the UK or has anybody any experiences using the Cinema XL as a centre in the Cinema 1 package.
    Also I am using a Yamaha 630 amp. Is the only connection to the subwoofer the LFE connection or is it better to wire the front ouputs to the subwoofer and then drive the frontspeakers from the subwoofer?
    Any help greatly appreciated
    Mike
