Eiren's Proposed Gaming HTPC Build
eiren
UPDATES:
BUILD SO FAR -
Case = Silverstone LC17B
Fans = 4 x Noctua R8 80mm + 1 x Silenx Ixtrema slim 80mm fan + Nexus PCI Slot Ventilation Brackets
Motherboard = Gigabyte GA-EP45-EXTREME
CPU = Intel Core 2 Quad Q9550
CPU Cooler = Noctua NH-U9B
PSU = Corsair HX850w
RAM = OCZ Blade Series 4GB (2x2GB) DDR2 PC2-9200C5 Low Voltage Dual Channel
Graphics card = Sapphire Radeon HD4870X2
Optical Drive = LG GGC-H20L Blu-Ray Reader & HD-DVD ROM SATA Drive
Hard Disk Drive = 1 x Samsung EcoGreen F2 1.5TB SATA-II 32MB Cache
Keyboard & Mouse = Logitech MX 5000 Wireless Desktop
6/7/2009 - Pictures of the build so far here: http://www.avforums.com/forums/home...proposed-gaming-htpc-build-4.html#post9867239
4/8/2009 - All complete in the build. Everything up and running except the media front end. CPU overclocked to 4.0GHz: http://www.avforums.com/forums/home-cinema-pcs/1014281-eirens-proposed-gaming-htpc-build-7.html#post10072402
Original post -
Right... here we go!
This is probably not a very exciting build to most of you since it more or less takes one of Razor's excellent templates for a gaming HTPC and runs with it. I do need some advice on it though. Here's what I've got so far:
Case - Silverstone LC17 (£69)
Fans - 3 x 80mm Coolink SWiF-801 + gaskets (3 x £8 + 3 x £2 gaskets)
Motherboard - Asus P5Q Pro Intel P45 (£105)
CPU - Intel Core 2 Quad Q8400 2.66GHz 4MB (£150)
Memory - 4GB of DDR2 1066Mhz (£35)
HDD - 1Tb Samsung F1 Spinpoint (£70)
CPU Cooler - Scythe Ninja II with 120mm fan (£42)
Graphics card - ATI Radeon HD4870 1GB (which will be upgraded to Crossfire later on) (£180)
Total = £681
[I've already got a spare 1000w PSU, so am sorted there.]
Now I know I can get HD audio via the 4870, so that should be all good.
My questions are:
1) What could I improve for minimal expense?
2) There are HIS HD4870 which are a lot more expensive than the standard ones that have better after market cooling on them. Are there better alternative coolers for the other 4870 models which would be better/cheaper? Would these be okay for a later Crossfire upgrade?
3) If I am running everything via my video processor to either my projector or plasma at 1080p, what is the optimal resolution to run games at on the PC? Do you run at the max. possible and have the cards down-convert everything to 1080p?
4) Is it possible to use Remote Desktop to remotely play games on the new PC from my old PC via the home network? Is it going to run like a dog... even for things like Sims 3?
Thanks in advance!
eiren
Sweet that looks good. Yeah I was going for a HIS one there, but after having a good look for the last 20 minutes or so... I am liking the look of the Sapphire Vapor-X or Toxic models... and they seem to be pretty reasonably priced too.
Seem to get some decent reviews as well... so they might be worth investigating too.
Razor
Thats a nice spec there mate. :smashin:
1. Not allot really are you going to overclock at all? You could get a more powerful graphics card if you so wished but its not necessary as next gen cards should be out in 4-5 months (ATI 5 series).
2. Wolvers answered that above
3. You will be able to run near enough all games bar crysis on full settings @ 1080p with AA. :)
4. I wouldn't advise it. Install the game on both systems (only one copy needed for this) and share your save game file across both systems.
BTW thanks for the mention. :smashin:
eiren
Thanks for the answers, mate and of course the inspiration. Credit where it's due and all that :D
I would like to try overclocking it, especially if the Ninja II will allow some tweaking of the CPU, and then I'd definitely look into overclocking the graphics card a bit. So it might be worth paying a bit extra now for a Sapphire Toxic or Vapor-X.
So is there actually a 1080p setting on games? Or does the card scale up or down to it from whatever the game is set to?
The problem with the answer to the last question is that my old PC is pretty tired spec wise, so not sure it would run many games now. Which is why I was hoping that the new PC could do the donkey work over the network.
Razor
1080p can be selected for 99% of games.
Just save your ave game files from your old pc, reinstall all your old games to your new pc. Then just place the save game files in the right folder. :)
eiren
Right the case has been ordered, so that's sorted. Next thing to get is the motherboard.
I've noticed there's several different versions of the Asus P5Q Pro.
1 - Asus P5Q PRO P45 Socket 775 8 Channel Audio ATX Motherboard - Ebuyer
2 - Asus P5Q-E P45 Socket 775 8 channel audio ATX Motherboard - Ebuyer
3 - ASUS P5Q PRO Turbo iP45 Socket 775 8 -Channel Audio ATX Motherboard - Ebuyer
I am thinking either 2 or 3 since they have eSATA connections for an external hard drive solution.
Any other major differences I am missing on those?
Razor
Asus likes to rattle out loads of the same mobo with slight differences to them. They are basically all the same mobo but they might have something added or removed. Compare them on the Asus website and go for the one you like. You wont be getting any worst or better performance from any of the above mobos. Esata is handy, I would definitely want that feature on my mobo. :)
eiren
Cheers for that info. I've ordered the P5Q-E as it has more stuff on it than the Pro (eSATA, backup BIOS chip etc), and I don't really need all the extra overclocking stuff on the Turbo version.
CPU decision next :smashin: which Quad Core to go for...
Razor
If your on a budget then get a Q6700. If not then a Q9550. :)
booyaka
eiren
Was going to go with the Q8400 2.66Ghz... but if the Q9550 is worth the extra ££ then I am sure I wont take much persuading :hiya:
Razor
The Q9550 is a better clocker than the Q8400. It is worth the extra cash IMO. :)
Ci4N
Fans - 30 x 80mm Collink SWiF-801 + gaskets (3 x £8 + 3 x £2 gaskets)
Total = £681
Where are you buying from? That's very cheap.
eiren
All over. It's actually cheaper than what I posted if you shop around by almost a good hundred pounds :thumbsup:
eiren
They're in Coventry, and usually pretty good:
Eclipse Computers
Question to the experts out there. Am I right in thinking that I won't need any other soundcard other than the on-board sound on the ATI 4870? Including games etc... although I understand that wouldn't support things like EAX?
Razor
Eclipse Computers
I had some issues with the on-board sound and DX10 games, however you might be fine. It seems it only effects some users and this about 3-4 months ago. It might be fixed by now. Give it a go and see how you get on. If you need a separate card go for an Auzentech Forte. :)
Razor
Cheers mate. As ever you're a font of wisdom!
I'll try the ATI card alone first of all.
No worries mate. :smashin:
Thats what I would do. :)
eiren
It's difficult to get info about just what the ATI cards can do audio wise. I can see it can pass 7.1 HD audio via HDMI... but there's nothing on the official ATI site, or even most of the hardware review sites, that mentions sound while gaming or in general... or whether it's just something that happens when watching HD content etc.
That's entirely awesome that you no longer need a separate sound card (in theory).
eiren
One last question for now... is it worth sticking a 92mm fan in the front of the LC17 case by the HDDs?
I understand that the middle cage is going to have to come out due to the HD4870 being too long to fit otherwise, but how about the other cage? Worth it?
How about the side fan? Worth sticking one there?
