Eight Legged Freaks Region 1 or 2 ? ?
Discussion in 'Movie Forum' started by BIONIC MAN, Feb 17, 2003.
  1. BIONIC MAN
    BIONIC MAN
    Jun 26, 2002
    956
    Nasa
    +40
    Need some advise
    I have been asked to get Eight Legged Freaks on dvd ,
    Could any one tell me which is the better one to go for
    Region 1 or Region 2 ? ? ,
    Do both Regions have the same Extra's etc also same running times ,
    I'am asking as you can get the Region 2 Cheper than Region 1 ,
    So do both discs have the same Extra's
    Thanks to all
    :rotfl:
  2. lentini
    lentini
    Jun 28, 2002
    3,549
    Dog Eater
    +455
  3. Jonny1973
    Jonny1973
    NTSC and PAL versions of the same film will never have the same running time regardless of any cuts made by the censor. PAL video has to be speeded up by 4% when it's created from film. NTSC also has to be speeded up but it's less than 1%.
    The 4% speed up of PAL raises the pitch of the sound and the speed up of NTSC causes stuttering pans (3:2 pulldown). Neither is perfect.
    I always go for NTSC but that's my preference.
  4. Jeff
    Jeff
    Jul 13, 2000
    5,489
    Basingstoke
    +256
    :confused:
    You mean slow down? Going from 24 to 23.976fps
    The picture quality on R2 releases are starting to get better than R1. The extra resolution is paying off now that compression artifacts are less of a problem due to better encodeing/filtering.
